Cant select open cl devices
  • Cant select open cl devices
    everytime i try to select opencl devices for vray rt i get an error message saying" ocldeviceselect.exe component not found and that it couldnt start because opencl.dll wasnt found.
    Sorry for the bad description but i have translated the error message from danish to english.
    Tried uninstalling and install with admin rights but no go
    Im running windows vista business 32 bit
    see attached files
    What is the version of your graphics drivers?
      I had the same problem directly after installing it when using the external opencl selector - the problem was gone after i opened max for the firsttime and used vray rt - now i can switch the opencl device with the external tool.
        Hm ok - thanks for the pointer, will keep an eye for it.
          Hi Vlado.
          my graphics driver version is 190.62
          I have a dell precision t 7400 with 2x geforce 8800 gtx gf cards.
          Tried again this morning after a reboot but its still the same.
          I will upgrade my gf driver and see if that could do the trick.
            Updated my graphics driver to 258.96 and it works like a charm.
