GPU usage
  • GPU usage
    Any way to display the GPU usage like the cpu one ?
    I whish i could check all my Gpu are used !
    I've a a quadro Fx 4800
    Yes, check out the EVGA Precision application. It will show you GPU load and memory usage similar to the Task Manager.
      Hi Vlado,
      Might be a side note, but since GPU RAM seems to be a bottleneck for some projects.
      I suppose there are several ways to conserve GPU memory...
      What happends if you load a "heavy" scene in "bounding box" mode in the viewport for example, would that free GPU memory for Vray RT since it wouldn't load all the triangles to the GPU memory?
        I guess it will save RAM on the GPU, but it would be best to try it out. Some GPU RAM is also used by Windows for the various user interface stuff.
