System sluggish while rendering
  • System sluggish while rendering
    I cant remember where i read it but is this problem eliminated if you have many GPU's? Or is it just that you can render on all the other GPU's leaving the graphic card that runs the display idle and this will help?
    Will this problem be persistent or is it just a problem for the beta version?
    Eivind Nag
    Things are better if you have a second GPU just for rendering, but if you don't - check the tips here: http://www.spot3d.com/vray/help/rt10...m#load_balance (where it says Balancing the GPU load).
      I have 2 x 480gtx cards and Im finding this also.
      Regards
      Steve
      My Portfolio
        Vlado, is there any way to balance the GPU load for just one of the GPU cards in a two-card system? This way at least one would render at full speed, and the other could be balanced with the display...
        I would like to add another 460 but wouldn't want to slow down both of them (rendering-wise) for the display.
        -Alan
          Not right now; it can be done in principle - will have to think about it.
            Knowing what can happen when you think about something - I will remain optimistic!
            -Alan
