RT GPU 2.002 bug_01
  • RT GPU 2.002 bug_01
    there is a bug with gamma
    I use gamma 2.2 scheme, sometime RT GPU renders with gamma 1.0, sometime 2.2, randomly
    tested with Max 2010 and 2011
    Best regards
    Can you explain a bit more? Which gamma parameter do you have in mind (input, output, Bitmap texture gamma)? Also, V-Ray RT will look at the sRGB button in the V-Ray VFB to decide if it should apply gamma correction to the ActiveShade window, which might be what you are seeing.
      the bug is random:
      i use gamma 2.2 in Max settings and gamma 2.2 in colour map.
      Just now I started the render and RT GPU renderized with gamma 1.0. I stopped the render without touch nothing, restarted and the gpu renderized with gamma 2.2
        now happens again
        started-->1.0 gamma...stopped...restarted-->2.2 gamma
          Ok will try to reproduce it here. Is anyone else having this issue?
            Nope, here it's all fine
            max2012 - vray 2.20.03
              I have. With RT CPU
