Vray using Intel AVX instructions?
  • Vray using Intel AVX instructions?
    Hi, we met with Intel to determine the best choice for a renderfarm, and the rep wanted to know if Vray uses the following:
    1) AVX instructions (new in Sandy Bridge)
    2) Intel compilers
    3) Intel librairies
    Also, what kind of thread scaling -can Vray use dual 8-core with HT (32 threads) as efficiently as dual quad-core?
    thanks
    I wouldnt know for 1 or 3 (i assume you are referring to TBB or alike?) but it is compiled using icc indeed. From vraylog.txt:
    Code:
    [2011/Mar/24|16:16:38] ============================================================
    [2011/Mar/24|16:16:38] Console created, V-Ray Adv 1.50.SP2 for x64 from Apr 16 2008, 23:32:09
    [2011/Mar/24|16:16:38] Compiled with Intel C++ compiler, version 10
      Not yet, although we are looking into it.
      2) Intel compilers
      Yes. The current V-Ray builds are compiled with Intel C++ version 11; we are in the process of evaluating version 12.
      3) Intel librairies
      No.
      That depends a lot on what kind of settings are you using. Some algorithms (e.g. brute force) scale better than others (e.g. the irradiance map). We have tested it on a 24 core machine (dual six core with hyperthreading) and it seems to be doing fine. We are also doing some work to further improve multithreading in various parts of V-Ray.
        Vlado, thank you very much for the awesome support!
