RT GPU and nvidia 275.27 beta driver
  • RT GPU and nvidia 275.27 beta driver
    Hello,
    it's seems that if RT gpu isn't able to build a new *.clbin file with the Nvidia 275.27 beta driver .
    If i delete the *.clbin file in temp that was created with older driver, vrayRTserver crash before building a new one.
    However , RT gpu is working great with the 275.27 beta driver and the old clbin file .
    *i'm in love with RTGPU but i miss some blend materials .
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    Thanks for the pointer; hopefully nVidia will fix this.
      I can't seem to get RT OpenCL to work on any driver younger than 270.61. I just tried the beta 280s and the issue persists. I also tried a Quadro 600, GTX 580, and GTX 590 in my machine with different drivers and I get the same results.
      I realize this is likely not Chaos Group's fault, but could Vlado start a sticky that keeps track of the latest drivers that are known to work, or does it really depend on what system you're running or even the luck of the draw?
      Thanks
        I don't think it depends on the system or GPU; just the particular OpenCL code that we have seems to crash the newer driver. On the bright side, this doesn't seem to happen with our latest OpenCL code which will go into the next V-Ray service pack, so hopefully things will be fine there.
          Thanks, Vlado! That's terrific news. Can you give us a hint of when you hope to be able to release RT SP3?
          Thanks again.
            Should be around November. If you need to have it working with the newer drivers, you can email me to vlado@chaosgroup.com and I'll get you an update.
              Same problem here with the new laptop DELL XPS17 with Intel HD 3000 and Nvidia 550M
              VRay-RT Crash with the new Driver 280.26.
              www.francescolegrenzi.com
              VRay - THE COMPLETE GUIDE - The book
              Corona - THE COMPLETE GUIDE - The book
              --- FACEBOOK ---
