hi!
I've just received a new workstation, installed 3dsmax and vray and all works perfectly except the Vray RT Gpu.
A Nvidia Quadro 4000 in installed on it and I'd like to make some test, so before starting 3dsmax I've launch "Set OpenCL device for V-ray RT", there's just Quadro 4000 and click on "Set Devices". All set correctly.
Finally I've started 3dsmax and launch RT Gpu, the Render Server starts automatically but soon an error window appear "V-Ray Standalone has stopped working - A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available"
While if I register V-ray RT Render server as a service any Error Window appears, but the Active Shader remains Black on "waiting for image data..."
The new workstation has Windows 7 ultimate 64 bit, 3dsmax 2011 and the latest V-ray version 2.10.01, and a Nvidia Quadro 4000.
Thank you very much for any help.
Bye!
Bye!
