Is it possible to use my local openCL card in addition to an openCL card that is sitting on a different (unused) computer or must all graphics cards be on the same local machine?
Using local openCL plus network openCL card
Kind Regards,
Richard Birket
http://www.blinkimage.com
----------------------------------->Tags: None
You can run V-Ray RT in distributed rendering mode - no matter if you use the CPU or the GPU version. However keep in mind that you might have to start the V-Ray RT render server manually on the remote machine from an interactive Windows sessiosn (i.e. not as a service) so that it can access the GPU.
VladoI only act like I know everything, Rogers.
Thanks Vlado. Seems to work brilliantly.Kind Regards,
Richard Birket
