Displacement with GPU ?
  • Displacement with GPU ?
    Heya
    Is Displacement working in GPU mode?
    Thanks, bye.
    Not right away, however you can use a Displace modifier.
      Vlado, are you saying that the VRAY Displacement modifier will show up in RT? I am just jumping into RT next week, and Displacement errors is something that often requires me to do a re-render. Thanks.
        VRayDisplacementMod will show in the CPU version if you enable in the V-Ray RT settings. For the GPU, you'll need to use the regular 3ds Max Displace modifier.
          Excellent, thank you for the help. Thanks to DADALs recent help, I am setting up my renderfarm w/ CPU's for RT & production.
