error api : 999
  • error api : 999
    hello,
    When i'm trying to render with more than 1 GTX580 and CUDA i have this error api 999.
    I have installed the last Nvidia driver.
    Any idea ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    How many is "more than 1"? My tests with up to 3 GPUs were fine. The specific error (999) doesn't give much info, it's just a generic CUDA error. Also, is this on any scene, or just a particular one?
      Hi Vlado,
      Now it's work .
      I've trying with distributed rendering and it's working fine . ( 1GPU in my Workstation and 2 GPU in a node )
      Then after i have trying without DR but 3 GPU in my workstation and now it's work .
      I think someting in my windows isn't activated before i use DR. Then DR have correct this and now everything is OK with or without DR and with or without more than 1 GPU ..
      Thanks you for your time .
      freelance 3D artist
      www.ghiom.com
        this error is back .
        Even i use only 1 GPU, everytime i'm trying to render with CUDA it's crashing with this error line code in Vray RT Render Server :
        ./src/ocl_tracedevice.cpp(1120) : Driver API error : 999
        I've trying to update my driver and it's the same crash with the same line .
        It's working with CPU
        it's building with Opencl and rendering. But it's look like some GPU are bugged.
        it's crashing with CUDA
        I open 3DSMAX, i'm setup the renderer to active shade and Vray RT
        i setup CUDA
        i start render and it's carshing Vray RT server .
        i have 3 GTX580 in this computer on 2 cubix xpander.
        Any idea ?
        freelance 3D artist
        www.ghiom.com
          Is that for any scene?
            yes .
            I'm starting 3DSMAX2012 x64
            I'm creating a sphere
            Setup Active Shade and choosing VRAY RT 2.30.02
            engine type : CUDA
            I Hit Render
            freelance 3D artist
            www.ghiom.com
              Find and solved !!
              Ok my fault ..
              I've take a look at my Cubix, because i have the idea that my GPU are dead or maybe not correctly plugged.
              And i have see that the Electrics wire form the Cubix to the GPU are a little unplugged
              I' ve pushed on them, restart my computer and everything is ok now.
              Thanks you, VRAY RT is working like a charm . It's my hardware the fault .
              freelance 3D artist
              www.ghiom.com
