Cuda Vray CarPaintMtl bug
  • Cuda Vray CarPaintMtl bug
    Seems Vray CarPaintMtl coat layer strength is not working as expected.
    Create a sphere and a camera.
    Apply a VrayCarPaintMtl to the sphere.
    add a HDRi in the environement slot
    start ActiveShade with VrayRT Cuda as engine type.
    if you setup the coat strength to 1 the coat isn't appear .
    if you setup the coat strength to 0 the coat is 100% visible.
    with CPu is the inverse like expected.
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    vray CarPaintMtl doesn´t work right in CUDA and OpenCL mode.
    @vlado: is this a big issue to fix? It would be great to have the possibility to use CarPaintMtl.
    Best regards
    Michael Kaiser
      It is for the moment an intentional limitation.
        Dang, I was really hoping to get GPU car paint in this update. I remember you saying that you had it working in internal builds so I hope we get it soon.
        -Alan
