RED LIGHT issues in distributed gpu render
  • RED LIGHT issues in distributed gpu render
    I'm testing now the new vray 2.3
    I have 2 identical systems with 4 GTX580 3GB each
    Launching a gpu render in distributed mode the slave machine renders some parts in red.
    If I render locally on the two systems the renders are ok
    If I activate the render using both systems the first system renders ok, the second system send a red image
    If I invert the test slave-master master-slave I got the same results.
    Show mask is deactivated (!)
    I repeat: two identical systems, same hardware, same drivers.
    COLOR CORRECT PLUGIN!...is the cause...
      That's a bit odd... can you get me the scene?
        it's an huge scene. I used colorcorrect plugin, the latest Max 2012 64 version.
        It produces reddish render only in distributed mode.
