when i load a map... i can se the EDGE of the map. The edge is in the bump map i think. the bump map is a simple jpg so no 16/32 bit, ec...
As you can see in the attachment.
In one image I exagerate the effect in a crop. In the other the effects is quite visible. but there is.
there is somthing to set in the parameters? like gpu texture size, ec...?
NB: The normal rendering ( or RT cpu render) HAS not this artefact.
