hi all, well ive been rolling various options around for months about what spec new workstation to build.
in the end it came down to a dual xeon or 1 or more oc'ed i7's
the thing that bugged me was the lack of overclockability on the sandy bridge xeons. i like to oc my hardware and get better bang for buck.
i also like fiddling round with bits of wire and soldering irons.
i also like things in neat packages.
so i came up with this:
looks normal enough.
midi tower case, a 3930k with an H80 cooler, 32gb ram, a samsung 256 gb ssd, and a 4gb gtx 670.
works very nice in max and photoshop.
looks like this inside:
not the cleanest install i agree, but certain hacking had to be done.
open the front and it looks like this:
so far so normal, but.... wait.. whats this?
an extra button?
you see, there is always a bit of extra space inside these pc cases, if you use micro atx quite a lot, and if you are neat with your wiring, really a lot of extra space. also, if you get a big enough power supply, you have plenty of juice left. mine is 1475w.
so, when im working in max or photoshop or reading the chaos forums, i use my workstation like normal, but when i want to render, i press THE RED BUTTON.
that activates this:
a second 3930k, mounted opposite the first. also with 32 gb ram and a samsung ssd. it shares the psu with the first one (custom wiring ) and is accessed with remote desktop from the main system.
both are nicely overclocked to 4.4 ghz, and cpu temps running stress testing (IBT) peak around 72 degrees. ive still got to optimise things a bit.. hoping to get the temps down a bit.
i also intend to fit a compact gigabit switch in the case too, so i can connect it all up internally. at the mo, they are both connected to an external switch.
id love a 10gb ethernet conenection between them, or infiniband or something, but for those prices i could buy another rendernode. - anyone got any suggestions?
basically means i have a compact, efficient workstation that breathes fire when i need it to.
cost about £3500 all in.
there is actually still space for a second gpu in there, but that may be pushing the thermals a touch far
main disadvantange over a dual cpu system, is i have 64 gb ram in there, but i can only ever use 32 in a scene.
an extra button?
