23501_22395 build debug
  • 23501_22395 build debug
    Hi Vlado,
    yesterday I downloaded the latest build
    I've found some bugs/issues:
    #1 loading a previous scene with vray planar lights and selecting "enable viewport shading" Max will crash
    #2 "invisible" option for vray lights doesn't work, it produces two intersecting reflections
    #3 refractions on thin glass walls are wrong
    #4 fireflies appear when using sun+ies or vray lights. If I disable the sun the fireflies disappear. If I use an environment+vray lights the fireflies disappear.
    #5 If I use a directlight with value 1 + vray ies lights + environment there no fireflies. Using a value of 2 the fireflies come back.
    #6 Every time I change a parameter Vray-rt reloads the scene
    #7 the #value on texturized vraylight material doesn't affect the power, no changes if you put 1 or 1000
    When you think to release a version with instances enabled and a realtime feedback?
ID:	876773Click image for larger version
ID:	876774Click image for larger version
ID:	876775Click image for larger version
ID:	876776Click image for larger version
    Thank you
    Regards
    specs:
    Cuda kernel
    Max 2012 64
    Nvidia driver: latest
    4 x GTX580 3GB
    Windows 7 Ultimate
    Thanks a lot for the feedback; however I would appreciate if you do not post stuff about the nightly builds here; there is a reason they are not released and there is no point to discuss work in progress here. Feel free to email me directly to vlado@chaosgroup.com and we'll work to have any issues resolved.
      ok, thank you.
        I have email a few times to get access to the nightly builds...but I have received to response from anyone at chaosgroup.
        Can I get access to the nightly builds??
        Eric
        "I have not failed. I've just found 10,000 ways that won't work."
        Thomas A. Edison
          Please forward your request to: support@chaosgroup.com
          Zdravko Keremidchiev
            Zdravko I sent the request four times already...including yesterday too.
            Thomas A. Edison
              I can see a few of our replays to your requests, maybe they are blocked at your side.
              You can contact us via Skype as well: chaossw
                That was it...Thank you!
                Thomas A. Edison
