Hi Vlado,
as you understand, it's very convenient tweak the maps inside 3ds max instead photoshop (little tweak, but important for the final result)
This is the main reason why I asked the support for Color Correct map in GPU mode.
In the same way, RGB Level (first) and the other parameters in the Output rollout will be very welcomed ))
PS a little "up" for the slice plane for VRayCamera ^___^
