Dear commuters,
I'd like to build a small renderfarm for vray|max and have many questions about compatibility issues.
1. Does vray support 64 Cores (4x AMD Opteron 6380) or max 32Cores ?
2. The internet says that the AMD Opteron 6380 has equal power to the Intel Xeon E5-2670 but AMD is 30% cheaper. Does VRay runs some algorithms wich are only supported on Intel CPU's? In which solution should I invest?
3. How many GBs of RAM should be available per core?
4. With 64Cores (4x CPUs) I'll need Windows Server 2008R2. Could this be a problem or is it an advantage?
5. When will it be possible to use GPU power on network render nodes?
kind regards,
Dennis
kind regards,
Dennis
