VRAY HDRI rotation, crashes VRAY RT GPU CUDA
  • VRAY HDRI rotation, crashes VRAY RT GPU CUDA
    Anyone experience this? Happens everytime I try to do a horizontal or vertical rotation to spherical map in VRay HDRI.
    Vray 2.40.03.
    Do you have the same map in the V-Ray environment overrides too?
      Hey Vlado, HDRI map is only assigned to vray dome light. Environment overrides are disabled.
        only disabled or without any maps?
        http://www.chaosgroup.com/forums/vbu...RayHDRI-Rotate
        Alessandro
          Interesting.. when its "disabled" (greyed out) it crashes, but when the field is completely blank (no map), then it works fine.
            This is similar issue like this posted by Alessandro, we will make a note about it.
            Thank you.
            Tashko Zashev | chaos.com
