Hi, I'm looking for some help building a workstation, and probably some render nodes.
I Use 3dstudio Max a lot, After effects, Photshop, A bit of premiere and illustrator, and Im looking forward to Use realflow, Fumefx or some other particle simulators
First of all, I have a budget of somewhere around $5000 USD and here's what I have come up to so far.
Case: Rosewill blackhawk ultra
Motherboard: EVGA SR-2
CPU: Xeon 5650 x 2 (need some advice here because im not sure if its worth it to spend about 2k on this processors, or about 1k on the 5645)
PSU: Corsair HX 1050
SSD: Samsung PRO 256 Gig (mainly for OS and Software installation)
SSD: Samsung PRO 512 Gig (mainly for storing textures, video, and current projects)
HDDs: Two 2 TB mechanical, Backups and Storing my files, Probably in RAID 1
Memory: G.Skill Ripjaws DDR3 1600 48 Gigs in total (that's all the mobo can handle)
Custom Watercooled not going for any fancy looks, just a very efficient cooling solution since I plan to overclock those xeons
Video card.......
Not sure what will do best for me, I have seen the new titan around, but Im not sure if this is the best way to go ATM, I have never used a Quadro card before, just gaming cards, So I don't know which way to go, BUT any way I go, I will keep on adding cards in the future to stack it to the GPU processing
OK, that's my idea of a decent workstation, Will pair it with some Dell ultrasharp monitors (I have a 2 monitor config atm, does it worth it to have 3 monitors?)
As for the nodes. they are more simple, here it goes
Case: Thermaltake Armor A30
Mobo: ASUS Rampage IV LGA 2011
Video card: Evga GX 650 (cheap card since no one will be working on this computers)
PSU: Corsair bronze 430W Modular
CPU: Intel 3930K (I do plan to overclock them too)
SSD HD: Samsung PRO 128 Gigs
Memory: Ripjaws DDR3 16 gigs (4x4gb)
CPU Cooler: Corsair Hydro H80i
So, mostly my concerns are:
Workstation
Do I need to water cool also the chipset if I plan to overclock the board? I do live in a place where we are usually at 30 to 40 c°
Do I need to water cool the video cards as well?
Do I need a larger PSU? And if so, why?
What Video card way should I go? I do understand that the industry is moving towards the GPU processing, but its not there, and probably it will take one or two years to get there, IMO, that being said, I do use VRAY RT a lot, mostly to check on my materials, reflections, and creating context in my images, PLEASE keep in mind the other software I mentioned, since some of them do use GPU for their renderings.
I havent done any watercooled station yet, but I've seen a lot of how to's, tutorials and whatnot, but if someone has something to add, please do so
Node
Any other suggestions for the MOBO? I'm not particulary fond of ASUS, or Gigabyte.
Do I need a better video card? I understand that GPU can be used over a network, but I'm not sure if this is viable because of the large amounts of data that must be shared over a network, any comments here will help
Do I need more memory?
How far could you think I could overclock this CPU with the corsair H80i?
Would you think another configuration will be more efficient than this one?
Well, I'm really looking forward to see what you guys think, hopefully Vlado could add some pointers too.
Video card.......
Workstation
Node
