AMD FX8350, i7 3930K (S2011) or i7 3770k for render slave
I've just built two machines each i7 3930k, I can successfully overclock it to 4.7 ghz under water cooling and the 6 cores perform as fast as my 12 xeon cores (in my workstation) while the xeon cpu was $1100 each so $2200 in total, where as the 3930k is $625 per cpu. I wish they made them go into dual mobos!
Cool, I think you can make them into rack servers as well but they won't be quiet. I have to maximize my space, so I can't have too many of them, so I gotta overclock to make them work x1.5 times faster probably will burn them out faster too...
Hopefully all parts will arrive today so I should be putting the test machine together later on.
i7 3930k, Corsair H80i CPU cooler, 32GB RAM, SSD disk and a £20 gfx card!!
I had bought a desktop case (a HTPC type model from Silverstone) as we wanted to stack these up, but it turns out that you can't really get a CPU cooler to fit in a case like that after all, so I have gone for a mid range mid-sized tower instead. Its a pain, as most of the space is wasted. Who needs space for so many DVD drives these days? Ideally, I just want a smallish case that will fit a CPU and big cooler, lots of ram and 1 hard disk. Perhaps a couple of GFX cards if we go down the RT GPU route at some later date.
If you're not gonna overclock you can just get stock cooler. The i7 3930K doesnt come boxed with a cooler, but a standard simple "stock" cooler will do apparently
How about sticking your system in a 2U rackmount case? I got a quote recently and locally a 2U rackmount including the condensed cooling works out about 33 percent more expensive than a standard tower case for the 3930K.
33 percent is a bit much, but if you're worried about space and power usage, maybe its an option?
Is socket 2011 going to be the standard for the next gen of desktop cpus?
LGA2011 supports current Sandy Bridge-E and upcoming Ivy Bridge-E CPUs. Btw there will be no >6 core CPUs in Ivy Bridge-E desktop line which is dissapointing.
Well, it is built and running. Some clever OC utility comes with the board and automatically ups the settings until it crashes and then uses those settings that 'passed'. It is over clocking by 36% and is stable in Prime95. I think the water cooling helps.
Trying to check that I am seeing 12 buckets dancing around in a DR render, but they move so quick its hard to tell. We did a screen grab and can count only 10 buckets from this new machine. The CPUs 12 cores are flat out when using task manager. What is the best way to check that all cores are working as they should?
