vrayedgestex RT GPU Wire Mesh Renders
  • vrayedgestex RT GPU Wire Mesh Renders
    I cant seam to get vrayedgestex to work with RT GPU, I guess this is due to it not being supported?
    Anyone got any tips to get the same effect that works with RT GPU?
    http://help.chaosgroup.com/vray/help...tex_params.htm
    Or correct me if it is possible & I am just not doing something quite right.
    Many thanks
    Simon
    Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
    VRayEdgesTex is not supported on the GPU right now, but perhaps you can put a UVW Map modifier in "Face" mode on the object and use a square texture (f.e. Tiles with Horiz. count and Vert. count equal to 1). This will work fine only for quad meshes though.
      Thanks Vlado good idea for a quick fix.
