HDRI rotation does not work in animation
  • HDRI rotation does not work in animation
    I am trying to render an animation using RT GPU that has a HDRI dome light. The HDRI rotates at certain frames however when rendering the animation it does not take this into consideration. If I render in single frame though it works fine.
    V-Ray version 3.00.07
    Just realised this may be due to lock to dome orientation being ticked. I will run a test and see.
      It didn't make a difference, I haven't tried rotating the light instead, I will try that. At the moment the horizontal rotation is animated in the material.
        Let us know if animating the light works; I will make a note to add support for animated rotation in the texture itself anyways.
