What usual review Bench tool is computing the closest/similar way to RT GPU?
  • What usual review Bench tool is computing the closest/similar way to RT GPU?
    Hi guys,
    I was wondering how I could compare any benchmark tool that are used to try out every hardware that come out.
    As a example, Anandtech has done a review of the GTX 980 here : http://www.anandtech.com/show/8526/n...-980-review/20
    Loads of bench-tool : LuxMark, CompuBench, Folding @ Home, SystemCompute, etc
    They all have different results with CG and they are not consistent.
    If I would like to use any of those review/tool to asses what CG I should use for rendering with RT GPU, what should that be?
    Thanks
    Stan
    3LP Team
    At the same time, I'm looking into what would be the best bang for bucks if I want to buy few cards. If I'm looking into Luxmark benchmarks (Stil waiting to see if this is somehow the closest benchmark related to RT GPU) the GTX 980 and the GTX 970 are not that far for each other.
    CF : http://www.anandtech.com/show/8568/t...w-feat-evga/14
    Having both 4Gb of ram, it seems to be more worth wile buying more GTX 970 than less GTX 980 for the same price and have more horse power, what do you guys think? Stan
    3LP Team
      Hey guys,
      No one know what benchmark tool is similar to RT in terms of performance charts?
      I just want to know how I can compare CG cards.
      In doubt, I'll consider Luxmark as a good place to start...
      Stan
      3LP Team
        I can't tell you what benchmark is closest to V-Ray RT, but we will test a bunch of GPUs here with the latest V-Ray version and we will share the results (having these numbers will tell, in fact, which benchmark is closest to the RT).
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Scene used - http://ftp.chaosgroup.com/support/benchmark_scene.zip with max paths per pixel = 512, so we are looking at the time of completion .
          V-Ray version official 3.10.02 for 3ds Max
          Note the different times with different driver versions.
          Soooo here are the results:
          Quadro K2200 / 341.05 - 9m 43,7s
          Quadro K6000 / 341.12 - 2m 13s
          Quadro K5200 / 341.05 - 3m 9,7s
          Quadro K4200 / 341.21 - 4m 54,7s
          GTX 550Ti / 340.52 - 11m 25s
          GTX 560 / 340.52 - 6m 49,7s
          GTX 560 / 335.23 - 6m 48s
          GTX 770 / 344.75 - 4m 22,6s
          GTX 770 / 340.52 - 5m 17,5s
          GTX 770 / 344.60 - 4m
          GTX 750 / 340.52 - 8m 55s
          GTX 570 / 334.89 - 4m 22s
          GTX 980 / 344.16 - 2m 57,7s
          GTX 980 / 347.09 - 2m 30,9s
          GTX 980M / 344.45 - 4m 32s
          GTX 480 / 340.52 - 4m 9.5s
          GTX 660Ti / 331.82 - 6m
          GTX 660Ti / 344.48 - 5m 45,7s
          GTX 690 / 340.52 - 2m 11s
          GTX 590 / 334.67 - 5m 12s
          Tesla K40 / 332.76 - 3m 10,6s
          Peter Matanov
          Chaos
            Great info, thanks a lot.
            Would you mind doing a few bench on few cards with Luxmark 2.0? Mainly the newer cards would be great : K40/gtx980/k6000
            The Room scene would be great.
            http://www.luxrender.net/wiki/LuxMark#Download
            The purpose would be to see how they scale compared to Vray RT.
            That way, in the future, we would have a performance index that would let us asses how they would perform in RT based on those results we can see all over the net.
            ie : My GTX 780 Ti does 1222 points
            Thanks a lot
            Stan
            3LP Team
              Luxmark's Room - OpenCL GPU only
              Quadro K5200 / 341.05 = 795
              GTX 980 / 347.09 = 1938
              Knowing your results and mine do the math ... you can't rely on this benchmark software to compare and scale GPUs for V-Ray RT CUDA rendering.
              Peter Matanov
              Chaos
                If Luxmark is based on OpenCL, then it's best to ignore it. nVidia has not paid attention to their OpenCL performance and it is not an indication of the true capabilities of the cards.
                  Thanks Slizer for that.
                  Vlado, you're right, (once again ) this opencl benchtool is not usable as I have this ratio :
                  GTX 780 TI : Vray : 134 / Luxmark : 1220 / Ratio : 9.10
                  GTX 980 : Vray : 150 / Luxmark : 1938 / Ratio : 12.92
                  K5200 : Vray : 190 / Luxmark : 795 / Ratio : 4.18
                  It's weird because you could expect the 980 to be better at cuda than the 780 Ti but it not, although it's better in opencl...
                  Vlado, what would you think of creating a little Vray benchtool based on cuda?
                  That way, features sites that trys out hardware could potentially integrate that in their benchtools.
                  they all seems to be based on opencl for now, so useless for us...
                  The bench scene seems to be the same for 4 years now and although Vray does evolve, we just need to asses the cards themselves.
                  Having a consistent benchtool will make it easier to see the evolution of cards over time as well. Currently the benchmarks page has results from different Vray versions so it's hard to ratio them out.
                  Stan
                  3LP Team
                    Another issue with Luxmark is that it's too simplistic. Newer generation cards like 980 may have some specific optimizations, but when you get to a complex code, the overall performance is what matters. And in that respect 980 is just slightly faster then 780. The only true benchmark for anyting is to run the actual software, there is no other reliable way...
                    V-Ray/PhoenixFD for Maya developer
                      Yes, I get that now.
                      This is exactly why I was asking if it was possible to create a bench tool using Vray. In the same idea as arionbench.
                      3LP Team
                        Hey guys,
                        Any idea if a easy look to benchmark GPUs with Vray would be possible and come out someday?
                        I was hoping to use Arionbench in the mean time but it doesn't seems to act as Vray so I'm not sure if any of this data is ok to use.
                        I used the GPU benchmark as usual and Arion to compare and here as some examples :
                        GTX 970 :
                        Vray : 198 sec
                        Arion : 222 sec
                        GTX 780 Ti :
                        Vray : 124sec
                        Arion : 119sec
                        Dual GTX 680 :
                        Vray : 129 sec
                        Arion : 128 sec
                        As you can see, some cards are faster with Arion and some with Vray, this seems to be like OpenCL and the previous debated Luxmark tool, it can't be used to asses cards with Vray, that's why a tool proper to Vray would be great. Any info on this?
                        Maybe it's just a mistake with the 970.
                        If someone could run few tests with Arion so we could have a better idea if it's usable or not compared to Vray, it would be great.
                        Here is the link to try it out :
                        https://dl.dropboxusercontent.com/u/...-%20v2.5.0.zip
                        Thanks
                        Stan
                        3LP Team
                          I thought Arion uses the CPU to help the calculations, could that mess up the benchmarks?
                            I guess it could but it doesn't use excessively the cpu, it seems to be used only to handle the gpu, or they would have coded it really badly to be working single threaded for the cpu to help rendering :
                            What I found is that my 780ti and my dual 680 are really close rendering with Vray and arion, but the cpu are completely different.
                            I would bet more on something to do with the 970 that waks out (either with arion or with vray)
                            Would be good to have some other data from arion to compare with Vray so we can see if it's only on few specific cards (maxwell architecture?) or if it's completely not relevant.
                            Or having a tool done by vray as simple to use as arion and then we can throw that arion out of the window
                            3LP Team
