GTX 7xx and 9xx on the same computer
  • GTX 7xx and 9xx on the same computer
    Hi guys, I'm about to go for new a GTX 980.
    Is there any issue having a GTX 780Ti and a GTX 980 on the same computer?
    I know it's two different architecture and it shouldn't be mixed up, is it still the case?
    Stan
    3LP Team
    We can maybe try to test this configuration here, but there is a high probability that it will not work. Let me see if we can try it out and I will let you know what happens.
      Thanks Vlado,
      Stan
      3LP Team
        For those who are interested, it does work without any issue, at least for what I've tried so far.
        Stan
        3LP Team
          Oooh good to know
            so i do have another question on that matter. I currently own a asus gtx titan and if i wanted to add another card like 2x 970tgx would cause a problem or not ?
            Thanks.
            ____________________
            WALEE / www.walee.com
              Well,
              I do have had issues after a bit of playing around.
              In fact, my 780Ti seems fried, and I'm sending it to RMA next week.
              Not sure if it has any relation with the fact of adding the GTX 970.
              I'll try again once I receive my 780Ti back from RMA but for the moment, I would not recommend crossing architectures.
              Stan
              3LP Team
                I made a test with the Octane benchmark scene and I can see that my GTX 980 and GTX 460 render fine together. So I assume Vray is also fine with rendering on GPUs with different architectures? At least when I rendered some things with RT, Vray didn't give errors using both these cards.
                Aleksandar Mitov
                www.renarvisuals.com
                office@renarvisuals.com
                AMD Ryzen 9 9950X 16-core
                96GB DDR5
                  It only depends on the driver - if it can support all the GPUs inside the machine, they will generally work. nVidia are dropping the support for some GPUs from time to time (in order to reduce the driver size, I guess). Lastly they've dropped the support for 9600GT series (so it stopped working together with my Titan and I had to replace it). There is list of supported GPUs that comes with every driver release (keep in mind that this list is usually per GPU type - GTX, Quadro, Tesla, etc; but if a GTX GPU is supported, it Quadro counterpart will be too - for example, if the driver supports Titan X, it will run fine with the Quadro M6000).
                  V-Ray will work with any number of GPUs and any mixture of architectures, as long as the driver can handle them too.
                  V-Ray fan.
                  Looking busy around GPUs ...
                  RTX ON
