when enable color map is on in output of a bitmap it is not display when using GPU !
  • when enable color map is on in output of a bitmap it is not display when using GPU !
    i couldn't find it in the docs of v-ray RT and it drove me crazy for a while because i couldn't understand why when rendering using the CPU my bitmap used as a diffuse was displayed in the render view but when using GPU CUDA the bitmap wasn't displayed and instead it showed only the diffuse color of the material.
    That was until i figured out that if you click on ENABLE COLOR MAP in the output section of the bitmap when using the GPU render method with vray RT it couldn't display the texture !
    So my question is : is this supposed to be normal ?
    ____________________
    WALEE / www.walee.com
    The current official build doesn't support it. However it works already in the nightly builds. If you are interested to check it out, please email me to vlado@chaosgroup.com
