Viewport speed test scene (post your GPU and results)
  • Viewport speed test scene (post your GPU and results)
    http://www.2shared.com/complete/ssBC...ity01-V1d.html
    Please put to fullscreen, play animation, count time.
    My GPU: Geforce 770 GTX 4GB
    Nitrous; 1920x1200
    Times: (W-wireframe, S-shaded, S+W-shaded+wireframe)
    W: 12s
    S: 12s
    S+E: 15s
    Luke Szeflinski
    :: www.lukx.com cgi
    Originally posted by lukx View Post
    https://www.dropbox.com/s/0q8nqfgpsj...1-V1d.zip?dl=0
    W: 12s
    S: 12s
    S+E: 15s
    750ti 13/14/17
    Max 2014, 1920x1080
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      should probably mention max version and screen res?
      max 2014 x64
      2560x1440
      geforce 670 gtx 4gb
      w:13.6s
      s:18.6 s
      s+e:20.4s
        max design 2015 x64
        1920x1080
        quadro K3100m 4Go
        w:10.1 s
        s:10.3 s
        s+e:10.9 s
        mekene
          Max Design 2015
          GeForce GTX Titan 1920x1200
          W: 16s
          S: 16s
          W+S: 18s
          Interestingly, collapsing all objects before playback gives much better results:
          W: 10s
          S: 11s
          W+S: 11s
            max 2014 x64
            2560x1440
            geforce 970 gtx 4gb
            w:11.5s
            s:11.5s
            s+e:14s
            3LP Team
              max 2014 x64
              1920x1080
              Quadro K5200
              w:37s
              s:40s
              s+30s
              "I have not failed. I've just found 10,000 ways that won't work."
              Thomas A. Edison
                Originally posted by eyepiz View Post
                max 2014 x64
                1920x1080
                Quadro K5200
                w:37s
                s:40s
                s+30s
                that's disappointing, shouldn't it be faster than the K3100m time post by theedge.
                just curious what are the specs of your machine?
                  Hmm tested on my main workstation that has a Quadro 5000 and the results are between 25-35 sec ! Very disappointing.
                  mekene
                    sorry just to double check, it's a 5000 not the newer k5000?
                    but still a better time than eyepiz even newer k5200
                      Yes an old 5000 not k5000
                      Now I'm not sure if playing an animation with thousands of objects involves only the GPU. The CPU must have an impact on those times I presume. Or am I wrong ?
                      mekene
                        Maybe display mode (directX/nitrous) is interesting also;
                        So here's mine:
                        Quadro 5000 (2-3yo); 3dsmax Design 2014; Nitrous; 1920x1200
                        W: 21 sec
                        S: 23 sec
                        W+E: 29 sec
                        I'll try this at home on my Quadro K4000 and GTX970 also
                        A.
                        www.digitaltwins.be
                          3DS Max 2015 x64, Nitrous, 7680x1440 (Triple Monitor), 2560x1440 (Single Monitor Res)
                          Quadro K5000
                          W: 17s
                          S: 17s
                          S+W: 19s
                          Troy Buckley | Technical Art Director
                          Midwest Studios
                            3ds max 2015 x64
                            2560x1600
                            Quadro K4200
                            W:10s
                            S:10s
                            S+W:11s
                            The machine is 4 days old
                            PS. Of course I run it full screen and remove the scene explorer tab on the UI
                            Dual Xeon 2690 v3, Asus Z10PE-D8 WS, 64GB, SSD Win10, TitanX(Maxwell)
                            • #15
                              3DS Max Design 2014 x64, Nitrous, 2560x1440, used a stopwatch app for timing.
                              Quadro K5000
                              W: 16.3s
                              S: 16.4s
                              S+E: 17.9s
                              I've been considering switching to a Titan X, but after seeing Zakkorn's times I wonder if I should look at the K4200...
