Originally posted by bibi5000
View Post
Will AMD FirePro Graphics cards work ok with VrayRT?
Looking busy around GPUs ...
RTX ON
Are we talking about the same scene here? I used this in my second test: https://dl.dropboxusercontent.com/u/...mark_scene.zip ("Benchmark 2.0")
Didn't change any settings, just clicked "render".
The results for this scene on the benchmark spread sheet for the M6000 are: 1 x M6000 3.20.02 / 346.35 (Linux) - 12m 26s
Originally posted by bibi5000 View PostAre we talking about the same scene here? I used this in my second test: https://dl.dropboxusercontent.com/u/...mark_scene.zip ("Benchmark 2.0")
I think that with 3.30.04 M6000 will give (much) smaller time than those 12 minutes. I will see if I can find one to test and update here with the results.V-Ray fan.
RTX ON
I've installed 3.30.04 and run the benchmark scene and it is much better. The render did continue as opposed to stopping at 500/512 so I had to stop the manually.
Screen shot attached for the render info but 2m 58s for 543 paths
(why does the yellow render info show a different time than the frame stamp?)
This is with both AMD cards installed checked to render:
AMD FirePro W9100 - 16GB GDDR5 Workstation Graphics Card (Hawaii)
AMD FirePro W5100 - 4GB GDDR5 Workstation Graphics Card (Bonaire)
I meant a difference in render times given the same scene setup to be honest. As the first try was 2.58 yet the second was 2.14 (3ds was closed and opened again in between that)
I haven't looked closely at noise in these..
It's no biggie, just an observation
ok, I'm curious what the M6000 can doLast edited by savage309; 04-02-2016, 06:14 AM.V-Ray fan.
RTX ON
Originally posted by bibi5000 View PostThank you for the benchmark savage309. Ich will try this again on the w8100 as soon as I find the time.
Just to clarify things: Should I leave Vray RT running after 2048 p/p are reached like you did?Windows 10 x64 l AMD 8350 8core (oc to 4.6Ghz) on customLoop l AMD Firepro W8100 8GB l 16GB RAM (8x2) Corsair Dom Plat 2400mhz l Asus Crosshair v Formula-Z l SSD OCZ Vector 256GB l 1200w NZXT Hale 90 v2 (gold certified)
Here is the result: 2816 paths/pixel, 14336 passes in 50m 33.8s.
I expected the w8100 somewhere at 50% or 30% of the M6000, based on that this benchmark, but comparing benchmarks may be a bit pointless.
Originally posted by bibi5000 View PostHere is the result: 2816 paths/pixel, 14336 passes in 50m 33.8s.
For our benchmark scene it seems to be around 26% of the M6000 - 13m vs 50m. Which is should be around the same percentage of the price as well ?
I would like to note again that RT GPU does not use any of the pro GPU features, so being a pro one doesn't give any benefit for this benchmark.V-Ray fan.
RTX ON
Any chance RT GPU will make some changes in the future to take advantage of more AMD pro GCN/OpenCL 2.0 features?
should I ditch AMD altogether and get a couple titan cards instead? My other other option is just get another W8100 and increase my VRAM to 16GB and hopefully increase my performance that way.Windows 10 x64 l AMD 8350 8core (oc to 4.6Ghz) on customLoop l AMD Firepro W8100 8GB l 16GB RAM (8x2) Corsair Dom Plat 2400mhz l Asus Crosshair v Formula-Z l SSD OCZ Vector 256GB l 1200w NZXT Hale 90 v2 (gold certified)
