V-Ray RT CUDA noise.
  • V-Ray RT CUDA noise.
    Just quick question. Shouldn't the noise be random in each frame when the option 'Lock noise pattern' is switched off ? Now it's off by default, but noise patter looks exactly the same when rendering animation.
    Best,
    Tomasz
    @wyszolmirski | Dabarti | FB | BE
    Yes, it should be random. Let me check what's going on with this option when render with RT.
    Tashko Zashev | chaos.com
      "Lock Noise pattern" is considered "always On" when render with V-Ray RT CPU & GPU. I have submitted a bug report to our developers.
        Thank you very much, this is indeed something that would be very helpful.
        Cheers
          Hey,
          Do you think that fix for that could get into nighly builds any time soon ?
          It looks pretty bad with static noise in animation
          Best,
            Yes, will get to it soon.
              This should be fixed for the next nightly/stable build.
                That's awesome !
                Thanks for quick fix.
                Tomasz
