Workstation Budget planning 2016
  • Workstation Budget planning 2016
    Hy!
    i would like to upgrade my workstation in 2016, so i want to make a view considerations about the new system and the availible budget.
    I'am doing mainly arch-viz (vray, much forest pro) but also some cad work.
    my current setup:
    win 7 ultimate
    Z68X-UD4-B3 Mainboard
    i7 2600k 4c/8t @ 4.4Ghz
    32GB DDR3 Ram 1333Mhz
    GTX 780ti 3GB
    planned setup:
    win 10
    MSI X99A SLI Plus
    i7 6950x 10c/20t (release Q2 ~1200€)
    HyperX Fury 64GB 8x8gb
    Palit GTX 980ti super jetstream 6Gb (option: GTX Titan X)
    Dark power pro 850
    Setup is about 3100€ (3500€)
    1. How you guys doing with win10?
    2. Is there a need for a Titan X (for forest scenes)?
    3. maybe the i7 6950x will be replaced with i7 6900K we will see prices and further specs soon.
    4. is there any point to go with a dual xeon setup?
    greets phil
    Greets Phil
    WS
    DUAL E5-2683 V3 28c/56t @2,6Ghz
    64GB Ram
    ASUS ROG STRIX OC 1080ti
    PALIT SUPER JETSTREAM 780ti
    Node
    I7 2600K @4,40GHZ,
    32GB RAM
    i would go with a bigger power supply...
    maybe you update your rig with a second GPU...
    GPU rendering is comming closer and i wont be surpriced if chaos has something up their sleeves...
      yeah you're right i think i will switch this to 1000w so it can handle two 980ti's
      thanks for the hint
      maybe someone found this useful
      calculate your power supply: http://www.bequiet.com/en/psucalculator
      Greets Phil
      WS
      64GB Ram
      Node
      I7 2600K @4,40GHZ,
      32GB RAM
        looks like a good setup.. im interested to see the reviews of that cpu before jumping in.
        a more advanced psu calculator if you are a stickler for detail..
        http://outervision.com/power-supply-calculator
          What would a rig like that cost?
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            Hy Bobby,
            here is a list with two possible setups.
            Maybe the 6950x is only 1000€... there are only rumors so i go with 1200€ (always better to plan more, you can see the impact now on the oculus
            Prices are from Austria.
            Cant wait to build up such a rig!
            Greets Phil
            Greets Phil
            WS
            64GB Ram
            Node
            I7 2600K @4,40GHZ,
            32GB RAM
              I was tired of waiting till the release of the i7 6950x!
              So i made a little chart for the decision about a the cpu for my new workstation!
              Very interessting results, best option for the budget is the new E5-2640 v4! Only 500€ more than the i7 6950x and nearly twice the power.
              Maybe it'll help somebody.
              Greets Phil
              WS
              64GB Ram
              Node
              I7 2600K @4,40GHZ,
              32GB RAM
                Some points regarding your calculation...
                You can't multiply the single core turbo to get the combined GHz. The all core turbo is always lower - sometimes much lower like for the 2640 v4 with 2.6GHz.
                https://en.wikipedia.org/wiki/List_o...l-processor.29
                Hyperthreading normally adds maybe 20-30%, so doubling the threads is not really helpful. And because all bigger intel CPUs use HT you can simply exclude it from the calculation.
                And i think Passmark is not the best tool to measure rendering performance. I have seen completely different results in the past when i compared the values to rendering benchmarks.
                  Thanks for your info, didn't mention that!
                  i updated the chart with the right calculation for the stepping.
                  i also made an graph.
                  One thing is very interessting, the E5-2620 v4 has a higher ratings than the 6950x an the dual setup is also 600€ cheaper!
                  Greets Phil
                  WS
                  64GB Ram
                  Node
                  I7 2600K @4,40GHZ,
                  32GB RAM
                    Hey Guys , just wondering if anyone can help me out with this computer I am about to order.
                    I want a fast rendering workstation to render personal projects at home. I have a 5k budget. What would you change on this build. Prices are in Aus dollar.
                    ASUS Z10PA-D8 Dual LGA 2011-3 ATX Workstation Motherboard ( 685 dol )
                    2x Xeon E5-2640v3 LGA 2011-3 2.6GHz (Turbo 3.4GHz) Processor ($1459.98 Each)
                    1x ASUS GeForce GTX 980 STRIX 4GB Video Card ($725.00)
                    4x Kingston 8GB (1x 8GB) DDR4 2133MHz ECC Memory KTD-PE421/8G ($117.98 Each)
                    Thanks
                      i would go for some more ram, 64gb at least
