FROM Vray RT FAQ page:
Why does my UI become sluggish when I use V-Ray RT GPU ?
– If you have multiple GPUs, you can speed up screen refresh time by removing the GPU used for monitor/viewport redraw from the devices that RT GPU uses for rendering.
– If you have only one GPU on your system, you could try reducing the value for Rays per pixel and/or Ray bundle size in the Performance section under the V-Ray RT tab in the Render Setup dialog. This will break up the data passed to the GPU into smaller chunks so that user interface requests can be processed faster. However, this might reduce rendering speed. Enable Show statistics to check the difference in render speed and to help find the optimal settings for your system.
Does this info suggest that I can potentally use 2 GPUS for rendering and 1 for viewport/activeshade?
In theory, can I use 2 AMD cards of the same architecture for rendering and an Nvidia card for viewport? Is there a way to install multiple drivers on a single computer but not have them interact per se and not cause issues?
What is the best course of action here?
