Hello,
I am currently testing RT GPU for my workflow, as it got considerably faster since the last releases. On two Titans it is great fun so far, apart from some problems.
What is bugging me most is the very limited bump mapping on GPU. I can only use bitmaps, but that has it's problems, too. It seems that I have to crank up the bump multiplier using a value of x5 to match the results from Vray Adv. Attached is a screenshot, and the bump effect with exactly the same value is hardly visible. If I make it around 5 times as stron on GPU, it's closer to the intended effect.
Regards
Oliver
Regards
Oliver
