Disable Distributed Rendering from Command line (3dsmaxcmd.exe)
  • Disable Distributed Rendering from Command line (3dsmaxcmd.exe)
    Is there some way to disable Distributed rendering from the command line when using 3dsmaxcmd.exe ? If we leave it on they every machine on the farm tries to use distributed rendering at the same time... Not a good thing.
    Ideally this would be disabled by default, but have a command line option to enable, though either way would work. If we could just add --no-distrubted or whatever to the command line options that would be great!
    Thanks.
