Dell 7910: Multi-GPU Question
  • Dell 7910: Multi-GPU Question
    For those of you running the Dell Precision Tower 7910, I need help determining how many GPUs I can run. I currently have one 980 Ti and a Quadro K4200. I can't find additional power plugs to supply an additional 980 Ti, but I can't imagine the case is already maxed out (1300 W).
    Dell Chat said the PSU is modular, but they don't sell cables to add on to the PSU and they weren't able to tell me what cables I'd need, nor were they even confident it could be done.
    Anyone have any insight?
    Work:
    Dell Precision T7910, Dual Xeon E5-2640 v4 @ 2.40GHz | 32GB RAM | NVIDIA Quadro P2000 5gb | NVIDIA GeForce GTX 980Ti 6GB | NVIDIA GeForce GTX 1080Ti 11GB
    V-Ray Benchmark: CPU 00:52 | GPU 00:32
    Home:
    AMD Threadripper 1950X 3.4GHz 16-Core | 32GB RAM | (2) NVIDIA GeForce GTX 1080Ti 11GB
    V-Ray Benchmark: CPU 00:47 | GPU 00:34
    https://pcpartpicker.com/list/kXKcxG
    Can you fit more than 2 dual slot video cards in that machine?
    "I have not failed. I've just found 10,000 ways that won't work."
    Thomas A. Edison
      Yes, physically, there is enough space for two dual slot cards and one single slot card. We dug around inside the case a bit more and found an extra un-used plug.
      Work:
      Home:
        Cool...do you use the the Quadro K4200 for the view port? I Always wondered if you could run Quadro Driver pushing the display and Geforce for the other cards.
        Thomas A. Edison
          Yeah, the Quadro is for Revit interaction mostly. May have to stick a fan in front of my case to help keep temps down since there won't be much breathing room between the GPUs...
          Work:
          Home:
