Worth it? I only use it for lighting setup.
EVGA GeForce GTX TITAN X 12GB SC
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Dang Amazon 1-Click purchase. I guess I'll find out if it's worth it. I am thinking on interiors it would be worth it.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostWorth it? I only use it for lighting setup."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
The view-port should perform better. I need a second monitor, so I'll eventually be getting a second 4k.
Originally posted by eyepiz View PostNot with a 36-Dual core machine. The Titan is about the equivalent of a 16 core machine in terms of speed. your 36 core machine much will be faster.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I do remember dropping 2 grand for a G5000 (I think that's what it was) and it stunk. It was probably the worst investment I made, however, the Titan X gets great reviews. If you guys don't think it'll benefit me, I'll cancel the order.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI do remember dropping 2 grand for a G5000 (I think that's what it was) and it stunk. It was probably the worst investment I made, however, the Titan X gets great reviews. If you guys don't think it'll benefit me, I'll cancel the order."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
Bobby one think to keep in mind is that the GTX's wont do 10-bit color. I remember you have one of those new 4k Samsung monitors. If I ever upgrade to 4k I'm probably gonna get a Quadro to take advantage of the 10-bit color those new monitors have."I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
Originally posted by eyepiz View PostI would try it out Amazon has a great return policy. I've always been led to believe that Quadros, even lower end ones are better for viewport than high end GTX's.
<_CFXNotificationTokenRegistration: 0x18062f10>Bobby Parker
phone: 2188206812
- Windows 11 Pro
After reading some other posts, I canceled the card.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Ended up getting the 980 TI, which seems to be a good middle ground. Both 36 core monster and card will arrive Tuesday.Bobby Parker
phone: 2188206812
- Windows 11 Pro
