Hi guys,
Just wondering if I could get some advice on a really cheap way of gaining lots of cores, and the downsides, for a mixture of DR and Network Rendering.
The conclusion i've come to is to get a refurbished hp blade system, the post economical way seems to me seems to go back to the g5 blades, ddr2 memory. low core speeds, no hyper-threading and no turbo-boost on the chips.
I realise lower processor speeds are slower, I assume a 4.8ghz processor should be in reason almost exactly twice as fast as a 2.4ghz and then twice again if it supports hypertheading. Am I correct here?
Also Ram speed are there any real disadvantages to slower memory like ddr2 for rendering?
Bear in mind that this sort of system could give you 128 cores at 2.4ghz ish' , for less than 1000gbp and these will be purely render slaves, running either centos or windows 7 pro depending on a maya or max route,
The only downside to me at the minute would be the noise and weight of the things.
