DR Render IP settings?
  • DR Render IP settings?
    I'm helping a client get set up with their nodes. Currently, they are using BB and DHCP. I'm trying to help them understand the benefits of using DR in their workflow. One of the questions that came up is that the nodes that they are using are all set to DHCP. Can BB/DR work with that, or do all of the nodes need to be static? For my setup, I have 5 nodes, all of which are static IP's.
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    You can use the computer names instead of IP with DR
    Kind Regards,
    Morne
      That is good news. I did not know that. Thanks.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
