Is there better option than i7-6950X ?
  • #16
    Thanks for input. Interesting. So now it would be good to know if 6950X performance over 6900k is big enough to be worth 700$ .
    Luke Szeflinski
    :: www.lukx.com cgi
    • #17
      Just check corona benchmark for CPU speeds... Xeons are way superior for rendering/sims, i7 6950X is a waste of money in my opinion, unless you really need that fast single core performance. For the same money you can get a used dual xeon with 50+ threads.
      • #18
        Dual setups are bad for sims. There's so much memory involved in them and when you've to transfer that across a bus from one cpu to another it gets really inefficient. You're not going to get double the sim speed from a dual cpu machine unfortunately, maybe 20 - 40% in things like fume / naiad.
        • #19
          oh good to know. So after looking at corona bench it's between i7-6900k - 2 minutes and 2x E5-2630 - 1m 20sec. I'll be honest it would be good to have some power for gaming also
          Luke Szeflinski
          :: www.lukx.com cgi
          • #20
            I'd love a small form factor machine that takes 64gb of ram and a 1070 / 1080, seems like it's always the motherboard only having 2 ram slots that gets me though. Would love something portable!
            • #21
              John you mean for Xeon build or i7? For i7 there is nice micro board: https://www.asus.com/pl/Motherboards/X99M_WS/
              Luke Szeflinski
              :: www.lukx.com cgi
              • #22
                Very interesting, will search into this so!
                • #23
                  John what rig you're rocking right now?
                  Luke Szeflinski
                  :: www.lukx.com cgi
                  • #24
                    Dual xeon hp's in work with some kind of geforce 9xx and an i7 at home in a huuuuuge case that I don't need
                    • #25
                      Hey john do you know of any sims benchmark where you can see the difference between i7 and xeons? As far as i know the most important thing when doing sims is disk velocity, then memory bandwidth, then only CPU speed. Coming from an i7 6850k and now using 2x e5-2683 v3 i notice a huge increase in rendering and sims. Just not sure if it is as a greater in crease in sims as in rendering.
                      For example:
                      i7 6950X (1500€) - Let's OC it to 3.8 - 3.8*10 (Cores) = 38 ghz
                      2x Xeon E5 2683-v3 (800€ both used) - OC to 2.6 - 2.6*28(Cores) = 72.8 ghz
                      Also lukx my single core speed is at 2.6ghz and games are fine If you play more recent games that use as much cores as possible even better.
                      • #26
                        I don't know of any benchmarks, it's based on our experience of two large jobs - the fx guys who're far better versed in this stuff preferred the higher clocked single xeons to the duals for their work.
                        • #27
                          one more thing worries me regarding Xeons... aren't max viewports heavily dependent on cpu? So if I will have 2.20Ghz Xeon it will be pain in bigger scenes ?
                          Luke Szeflinski
                          :: www.lukx.com cgi
                          • #28
                            For example:
                            Your single core speed should be 3 Ghz without OC and with 3.165
                            Greets Phil
                            WS
                            DUAL E5-2683 V3 28c/56t @2,6Ghz
                            64GB Ram
                            ASUS ROG STRIX OC 1080ti
                            PALIT SUPER JETSTREAM 780ti
                            Node
                            I7 2600K @4,40GHZ,
                            32GB RAM
                            • #29
                              I'm planning to upgrade some time this year from my 3-year old i7 4930k and I'm trying to figure out which CPU is better. My picks so far are E5-2679 v4 and i7 6950x. Any suggestions which is better and why? I know one of the advantages of the xeon is that I would be able to add another one on the same PC in a few years time if more performance is needed, thus saving space, but other than that? For example, which one is faster, does the 2 times larger L3 cache of the xeon make any difference in rendering/daily work etc. etc.?
                              If my math is right, the xeon is 20 cores x 3.30Ghz = 66 Ghz while the i7 is 10 cores x 3.50 Ghz = 35 Ghz. So without overclocking any of them, the Xeon should be 2 times faster? And if I overclock 6950x to 4.40 Ghz the xeon would still be 50% faster?
                              My main concern with the xeon is the single core performance. If I overclock the 6950x to 4.40 Ghz it will be 30-35% faster in single-threaded tasks, am I right?
                              Any thoughts are appreciated.
                              Aleksandar Mitov
                              www.renarvisuals.com
                              office@renarvisuals.com
                              AMD Ryzen 9 9950X 16-core
                              96GB DDR5
                              • #30
                                You are absolutely right.
                                I don't think the cache changes anything, it's all about Ghtz IMHO
                                Stan
