DR render times longer?
  • DR render times longer?
    I'm setting up my small render farm with GPUs and running tests to make sure everything is working as expected.
    My WS has 2x980Ti's and when I render a scene I have with a refractive object i get a render time of 3:29s noise at 0.05.
    When I add a render node with a single 970 to the mix via DR, my render time is 4:03s...an increase in render time.
    I noticed the light cache gets built twice for the DR render, which took 30s approx, but why would the 3 GPUs not still render faster?
    I'm using 3.5 beta on all, max 2016, win 7 64 bit pro on all. Only asset is an hdri on a dome light that I have copied to the node under the same path as the ws.
    Any idea what I could check here?
    This is using production mode RT GPU...thanks.
    Maybe I'm getting a bottleneck somewhere, perhaps the network?
    If I ran four gpus from the same mb, would this help?
    Are their limitations to running multiple gpus past a certain point...I just read another post here where it was mentioned 2 cards might be faster then 3, if ui performance causes reducing rpp and rpb. I'm still trying to figure out what those are and how they work.
