Understanding RBS and RPP settings?
  • Understanding RBS and RPP settings?
    In doing some tests:
    - reducing these values to a point will give back viewport performance but makes render times longer...I understand that.
    - increasing these values help utilize GPUs better, causing viewport performance to become slow, but faster render times...I understand that.
    - When invoking DR nodes, it was stated to increase these values, but it seemed when increased beyond a point, there was no faster render times AND I observed certain GPUs usage would go to 0% (on ws) while other GPUs on nodes would still be 100%.
    - I've also observed reducing the values at a certain range, would oscillate the GPU usages more but would give faster overall render time when DR over a gigabit network.
    Here is what I tried using 2x980ti on ws and 1x970 on node via DR
    RBS 256
    RPP 64
    4:06s
    RBS 256 (duplicate for comparison)
    RPP 64
    3:48s
    RBS 256 (triplicate for comparison)
    RPP 64
    4:04s
    RBS 32
    RPP 1
    9:23s
    I did get very good viewport/monitor performance
    RBS 256
    RPP 80
    4:08s
    RBS 320 (I added 64)
    RPP 80 (I added 16)
    3:54s
    RBS 384 (I added 64)
    RPP 96 (I added 16)
    3:52s
    RBS 192
    RPP 8
    3:32s
    So you can see when adding to these values past a certain point, no increase in render times, but going back from 256/64 to 192/8 gave faster render times but more GPU oscillation.
    Am I hitting a bottleneck?
    Should I run some initial tests when I make a new scene to see what values work best?
    EDIT:
    All the above tests were run using 3.5.01 beta, I thought I would switch back to 3.4.03 for kicks and the render times were longer, so whatever improvements were made in 3.5 are working well.
    11:14 AM 12/14/2016 Switched back to 3.40.03 (non-beta)
    RBS 64 (these were defaults after installing)
    RPP 4 (these were defaults after installing)
    Plate14.max
    1280x720
    RT GPU noise 0.05 2 cards on ws (2 x 980 ti)
    5:16s
    kernals were recomplied
    lc built was about same time
    11:22 AM 12/14/2016
    RBS 256
    RPP 64
    Plate14.max
    1280x720
    6:38s
    11:37 AM 12/14/2016
    RBS 256
    RPP 64
    Plate14.max
    1280x720
    6:36s
    11:46 AM 12/14/2016
    RBS 256
    RPP 64
    Plate14.max
    1280x720
    RT GPU noise 0.05 2 cards on ws (2 x 980 ti) + DR EVGA 970 on Sys12
    7:53s
    11:57 AM 12/14/2016 (duplicate)
    RBS 256
    RPP 64
    Plate14.max
    1280x720
    7:21s
