Animated Noise Map on GPU
  • Animated Noise Map on GPU
    I'm trying to animate VRayFur via Noise Map (with animated Phase value) acting as a layer mask in Composite Map driving bend direction of Fur - to no avail so far.
    Anything that might not work on GPU in this setup?
    Marcin Piotrowski
    youtube
    Nothing that I am aware of. Which host app is that and which V-Ray version ?
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Still no luck with that setup. It works ok if I render single frame. If I'm rendering sequence the fur does not update between frames.
      3ds max 2015 (17.0 SP3)
      VRay 3.40.03 (RT GPU)
      scene:
      animated VRayFur.zip
      Marcin Piotrowski
      youtube
        Thanks a lot for the scene!
        It really looks like something that we have missed. I've logged the bug and we will let you know when it is fixes.
        Best,
        Blago.
        V-Ray fan.
        RTX ON
          in the meantime is there a way to force VRayFur to update for every frame via script?
          Marcin Piotrowski
          youtube
            I can't find a way to workaround this right now since the fur animation is not exported to the RT at all. We will notify you as soon as the fix came out.
            Tashko Zashev | chaos.com
              thanks a lot.
              Marcin Piotrowski
              youtube
                This is fixed for the next beta release.
                Peter Matanov
                Chaos
                  thanks for update.
                  Marcin Piotrowski
                  youtube
