Sli?
  • Sli?
    New to multiple GPU rendering. Is SLI used?
    V-Ray can use all the GPUs it can find without SLI. SLI is for games and will only cause troubles in raytracing.
    Check links there http://forums.chaosgroup.com/showthr...d-useful-links
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Thanks for the help
        Best,
        Blago.
        Well I have a wonderful green glowing HB-SLI-Bridge in my system now, and I'm wondering if it would be better, performance-wise, to remove it and/or if i should disable SLI in my system-settings. Are there any performance-gains to expect when disabling SLI because so far I was not running into problems with SLI on.
        Volker Troy
        www.pixelwerk.at
        +43 (0) 664 / 3 820 810
        Radetzkystrasse 102 a
        A-6845 Hohenems
        Austria
          I am not aware of any advantages, just potential problems. But if it works fine already, I don't think you have to do anything extra.
          Best,
          Blago.
          V-Ray fan.
          RTX ON
            You might want to check two things. One, make sure RT/GPU is using all available GPU power (typically 90 to 100 percent), and two, make sure you have all available VRAM for rendering.
            I have seen both issues crop up while using SLI between GPU boards...
            -Alan
