Originally posted by super gnu
View Post
Phew
I think you're absolutely right to mention it took you a month - I think I was rushing things a bit (though I am trying to get this out of the way whilst I have a window of opportunity, work-wise).
Once you mentioned my first riser cables were the wrong ones, I knew that the correct 30cm cable (as opposed to the 80cm one I chose mistakenly) meant this design had to be absolutely right - so, yes, I have already done the all important critical spline test
Now it's down to those Riser cables.
Bio recommends powered riser card/cables...... (which Moddiy do at around ?15 each).......
Moddiy,com recommend the non-powered gold-plated, shielded ones over those (at ?32.99 a pop.....).
My head tells me to go for what Bio recommends - I'd like as much power requirements to be taken away from the mb end of things (psu 760w) and put those demands on the GPU PSU's (2 x 1500w).
This one
https://www.moddiy.com/products/PCI%...2830cm%29.html
PS - I think you're right about squeezing it down smaller, but I wanted to give the same about of space these cards would have if I were only installing 3 on my mobo, i;e how they'd naturally be spaced out in that scenario. Plus also to let some air between them all. I think that keeping it this size will give me a bit of wiggle room if I do end up needing to squeeze the cards more together, say if those riser cables need it... (or if I ever need to reuse it for 8 cards someday).
