is this article suggestions good for setting up two rendering nodes?
  • #16
    A single threadripper 1950x is faster than dual E5 2660 v3.
    I saw from your website that your based in India. I used pcpartpicker to create this list. it's only an example so get a second opinion. in dollars it's a bit under $4000. (you also need a cheap or 2nd hand graphics card as the motherboard has no onboard graphics).
    https://in.pcpartpicker.com/list/BkyqYr
    • #17
      I just calculate the total ghz to cost of total system. 16core x 4ghz is 64ghz. 20core x 2.6ghz is 52ghz.
      • #18
        Thanks a lot! This is a great help, you saved my money! Going for threadripper!! With xeon i was thinking of using AXXRMM4LITE Hardware LIC Key For Remote for remote control. any similar approach available for threadripper? Thanks once again!
        Prateek Vishwa
        sigpic
        www.prateekvishwa.com
        https://www.facebook.com/pages/PVDS/161239543925007
        • #19
          Thank you all for your suggestions! Finally my Machine is at home!
          Prateek Vishwa
          sigpic
          • #20
            is this card good for display? Gigabyte AORUS GeForce GTX 1060 6G REV 2.0 Computer Graphics Card - GV-N1060AORUS-6GD REV2.0
            Prateek Vishwa
            sigpic
            • #21
              I got this PC assembled around 8 Months ago.. Until now- 1st My Corsair Hydro cooler ( Hydro series H100i V2) got collapsed! i.e within 6 months & now Corsair power supply ( AX860i) i.e within 8 months .. Is that brand so bad that lifetime of their product is not even 1 year?
              And RMA take 2 weeks for replacement! these products are so expensive.. how can one afford to keep such parts in spare for such events..
              Prateek Vishwa
              sigpic
              • #22
                I have 4 power supplies from Corsair - 2 x HX1200i (bought 1 year ago) and 2 x AX860 (bought 4-5 years ago). All of them work perfectly fine so far. Maybe bad luck?
                Aleksandar Mitov
                www.renarvisuals.com
                office@renarvisuals.com
                AMD Ryzen 9 9950X 16-core
                96GB DDR5
                • #23
                  My corsair H80i lasted about 3 years, replaced it with an Antec
                  Kind Regards,
                  Morne
                  • #24
                    I was facing this issue of random restart . it was happening 5 to 6 times in a day!.. i did basic checkup of ram etc & when i did self-test of PCU it failed.. i took my entire CPU to service centre for them to check & surprisingly it worked perfectly fine entire day at there center!.. they suspecting a faulty power supply cable.. i have changed the cable.. lets see what happens next.
                    Prateek Vishwa
                    sigpic
