KVM switch for quiet workplace
  • KVM switch for quiet workplace
    So here's my idea....
    I want to build 4 new workstations with 4 gpu' s (1080ti) in them. They would be rack mounted and kept in a server room that is nice and cool and more importantly away from the office where everyone is working... so no heat or noise.
    But in order for my idea to work, the keyboard, mouse and 2 or 3 monitors would need to be connected to each workstation by some sort of KVM switch...
    Anyone had any experience with this sort of setup? Or would I be better off just building the workstations in normal (big arse) cases?
    Any ideas/thoughts or help would be much appreciated!
    Nick Martin
    ScreenAge - 3D Visualisation
    www.screenage.com.au
    You need to look into "pc over ip", or teradici device. Its essentially allowing you to establish a fast connection to a machine on a local or remote network. For each workstation / machine you can have one device. At some studios I worked at they had 2-3 devices on their desk, switching between them via kvm.
    There are some limitations with it though, some don't like dual monitor setup, others don't work with tablets (sensitivity)...
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks Dmitry... looking into it now. Do you know if there is any performance issues with pc over ip? Does it feel like you are connected to your workstation normally or is there a bit of a lag? Any latency when using max etc would be pretty much a deal breaker.
      Nick Martin
        In case anyone else is interested in this stuff - found this vid which explains PCoIP pretty well.
        https://www.youtube.com/watch?time_c...&v=NWjhAHDQZ7E
        Nick Martin
          I have 3 computers and share the mouse and keyboard with all of them with this switch:
          https://www.newegg.com/Product/Produ...82E16817399127
          Been using this for a few years and it works nicely!
            CORRECTION!
            Oops that one was for 2 computers, I'm actually using this one!
            https://www.iogear.com/product/GUS404/
