If I set windows 10 power management to performance then my CPU idles at 3.7GHz.
But when I use Vray the clock speed drops to:
1) around 3.45GHz full load (with XMP profile enabled in the BIOS i.e RAM overclocked to a 2933MHz)
2) around 3.57GHz full load (With XMP diabled i.e running RAM at native 2133MHz)
If I try chaosbench the clock speed sits around 3.48GHz
When I first build the machine I had all cores maxing out at 3.7GHz whilst rendering.
This is all without any manual overclocking apart from enabling the RAM XMP profile. CPU temps are around 55 deg.
Any ideas why this is the case?
