I'm after someone that can take 3d scan data and build perfect fit panels over the top of the data.
There are about 9 exterior panels to do as the rest of the car is finished.
First off you would need to show previous work, then sign an NDA with my company (digitally is fine), then I can give you the FBX or Max file to quote on.
It's a major brand supercar - but because it's white label work you can't share the data or put it in your folio, this will be covered in the NDA.
It's pretty urgent so ideally you would be free asap.
Thanks,
Elliot
Thanks,
Elliot
