Populate:Terrain
  • Populate:Terrain
    I love the script and I use it on all my exterior scenes. Lately, it fails on pretty simple shapes, so is there a good alternative?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    The only way I get the plugin to work is starting off with large sizes and keep dropping the size to what I want. If I start with a small size MAX just locks up. How else can you make equal grids on a ploy? You would link it MAX could do it natively.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I love Populate Terrain, but I've had it fail as well a couple of times. It seems as if the plane has an 'edge' or polygons that are not part of the general surface it will fail. Usually easy to find though.
        It used to do it super fast, but now even simple shapes seem to struggle. It is an old script and I don't think it has been update in years.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I use the full version of TerrainAxe (https://www.flyingcfx.com/) for landscaping. It needs a deeper learning curve and some patience if you need help from the author. But any question and problem I had was eventually solved. If you examine all the help videos close you will see it's potential. I'm currently using it with Max2018, so not sure how is Max2019 compatibility.
            After research for an alternative, I did see this one. I'll check it out deeper.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Same here. Shame cause this is one useful script. The workaround I found is to use the Max's Terrain compound and then apply Populate in retopo mode.
                I don't suppose anyone has managed to get Populate Terrain installed and working in Max 2019? Colleague asking...
                Kind Regards,
                Richard Birket
                http://www.blinkimage.com
                  Yes, I have it working.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    What did you do to get it working? I'm getting errors, including:
                    Runtime error: Not creatable: Normalize_Spl
                    As I understand from Autodesk forum, Normalize_Spl has been replaced.
                    Any idea how to contact the script's author? I would definitely chip in $$ for an update.
                    Normalize_Spl is the old deprecated modifier which was replaced with the Normalize_Spline2 modifier (as a part of the spline tools update). I'd
                      Hmmm... I don't know, it works fine here. I don't think I did anything special. I am on MAX 2019
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        seriously? it will not work at all for me. What version are you using?
                          I am using MAX 2019 and it worked in MAX 2018, too.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Yes, that's what I thought. Wondering about the version of the populate plugin you're using. Really bothered by this; it was an integral tool for me. I guess I'll look into TerrainAxe, or try to find the author of populate and ask for a recompile.
                            • #15
                              Here is the executable
                              https://files.acrobat.com/a/preview/...7-6f484494f69c
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
