Project Lavina
  • #16
    This is GPU rendering, but on steroids
    as such it does obey some of the limitations a GPU render engine has. However it works Out-of-core, so you are not limited by VRAM.
    The Arnold checkbox, about GPU acceleration is another thing. It allows you to render on the GPU instead of the CPU. It's like switching from V-Ray to V-Ray GPU.
    RTX provides additional acceleration of the GPU, so it is essentially acceleration of the GPU acceleration.
    The demo here is using RTX through Microsoft's DXR technology and V-Ray GPU uses NVidia CUDA, so as Vlado said, we are exploring how we can use RTX in V-Ray GPU, but that will take some time.
    Meanwhile here is a little demo of our initial RTX support in V-Ray GPU
    https://www.youtube.com/watch?v=yVflNdzmKjg
    Alexander Soklev | Team Lead | V-Ray GPU
    • #17
      Thanks for answers! I always loves when dev give an insight.
      So.. VRay uses RTX via DXR and VRay GPU uses RIX via CUDA?
      Then what's the different between two?
      Is this mean shader evaluation still happening on CPU side for VRay?
      Then can we use all max legacy shader with RTX acceleration?
      Is it more like using Embree?
      Sorry for many questions!
      • #18
        Truly amazing stuff here.
