Line Art from .max files?
  • Line Art from .max files?
    Does anyone know of a way to get fairly clean 3D line art from objects that were hand modeled (such as a task chair)? I'm wondering if there's a format I can export to and bring it into AutoCAD (which I don't own), or Inventor and be able to translate that way, or maybe there's a plugin somewhere?
    These examples were created from within Inventor, so it needs to be similar.
    Thanks.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Illustrate ?
    http://www.davidgould.com/Illustrate...lustrate53.htm
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      You can export 3dmax files to .dwg and open them in CAD. Just not sure what capabilities you'll have in CAD to manipulate the line work.
      Brendan Coyle | www.brendancoyle.com
        Export the model to AutoCAD (dwg)
        In AutoCAD, orbit until you have an angle you like (or setup a camera), or use DDVPOINT to select an ortho view
        then HIDE (gives you what you see above).
        You can also then print to PDF to whatever size you want (no rendering needed)
        OR
        in Max render settings disable lights. Switch off GI. Add vraylight as an override material and make it white. In Environment choose a white background. Add VRayToon. render
        Kind Regards,
        Morne
          Thanks, Morne! With the CAD method, I'm so close... But I can't get it to export to PDF without errors. Even if I could get the background to go White and get a screen shot I think that might work... But I don't know CAD very well.
          I tried the VRayToon approach and the whole things renders black, so that doesn't look like it would work...
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            I figured out how to get a white background and can do screen grabs, but the antialiasing is a bit much. Hmmmm There must be a way to export it cleanly.
            David Anderson
            Software:
            Windows 10 Pro
            Hardware:
            Puget Systems
            TRX40 EATX
            128GB RAM
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
                Instead of exporting to PDF, I tried using "Plot" and selecting PDF from there. That seemed to work! Any ideas how I would get the arm in the foreground to show up better, or even thicker lines?
                David Anderson
                Software:
                Windows 10 Pro
                Hardware:
                Puget Systems
                TRX40 EATX
                128GB RAM
                  Here's a quick max file for you that I slapped together in 2 seconds. Excuse the "modern" chair and replace with yours (just delete everything besides the camera, then merge your chair in here). Render
                  Kind Regards,
                  Morne
                    And here's the max file
                    Kind Regards,
                    Morne
                      I must be doing something wrong then. I merged my chair into your scene, added Toon to Render Elements and hit render. Still black. Very strange.
                      David Anderson
                      Software:
                      Windows 10 Pro
                      Hardware:
                      Puget Systems
                      TRX40 EATX
                      128GB RAM
                        I just sent you a PM with a link to my chair if you get a chance. Thanks for your help!
                        David Anderson
                        Software:
                        Windows 10 Pro
                        Hardware:
                        Puget Systems
                        TRX40 EATX
                        128GB RAM
                          No dont add anything, just merge and render (the file you sent me has the camera pointing AWAY from the chair)
                          If you do decide to add a toon shader, here's the results from your file:
                          Kind Regards,
                          Morne
                            You can adjust the toon settings under max environment settings and adjust "normal threshold" and "overlap threshold" to increase/decrease the effect
                            Kind Regards,
                            Morne
                            • #15
                              Thank you so much! I didn't realize it's an atmospheric effect. Also, I was trying to use IPR which has something to do with it not working. As for the camera pointed the wrong way, um... we'll just let that one go. haha.
                              Dave
                              David Anderson
                              Software:
                              Windows 10 Pro
                              Hardware:
                              Puget Systems
                              TRX40 EATX
                              128GB RAM
