"Seamless" fabrics are tiling
  • #16
    Okay, so I'm obviously not understanding what to do... The larger area represents a single seamless swatch that is tiled. The smaller region render represents a composite map with noise map masks. Both the material and noise maps masks are offset from one another. Yet it renders the same. Bumps and Displacement are off as well. Any further help would be deeply appreciated
    Dave
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    • #17
      What are the offsets for the textures you are using? Should not be whole numbers like 1.0, 2.0 because then it would end up at the same place.
      Rens Heeren
      Generalist
      WEBSITE - IMDB - LINKEDIN - OSL SHADERS
      • #18
        Since it doesn't go above 1, I tried increments of .1 and also .2 for each. That made no difference.
        Currently:
        Top of stack .8
        Bottom of stack 0 (decrease by .2 each time
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
        • #19
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
          • #20
            This runs through it well - http://bertrand-benoit.com/blog/naka...road-tutorial/
            And here too - http://neilblevins.com/cg_education/...ling_trick.htm
            • #21
              I think I did it! The burlapy feel gets a bit lost, but at least there's no visible tiles. Turns out I was trying to change the positioning in the bitmap parameters and not the actual coordinates... Also, it seems like a smaller (1-2) noise parameter works well. Larger parameters made it look really soft.
              Thanks, everyone!
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
              • #22
                A good thing to try doing is use your render elements to check out your masking. Put in an extratex element with each of the noise maps you're using (so 4 of them in your case) and see roughly what size each of them appears at in the final render - if they're really small they won't give you a huge amount of benefit and are just making things fussy, you probably want each blotch of noise to be about the size of a tile roughly so you're getting plenty out of each layer. Also get rid of the mask on the very bottom layer, you don't want to accidentally see through to the bottom layer and have that masked out in areas too or you'll have holes visible!
